mchughpd
#1 Posted : Monday, December 21, 2009 7:01:14 AM(UTC)
mchughpd
replaced water valve.,still no water out of water dispensor on front of door. water comes out of valve when dr swt is pushed. its almost like the line is frozen inside fzr dr, is this possible and what do I do about it. ice works fine
#2 Posted : Monday, December 21, 2009 10:19:30 AM(UTC)
Quote:
... its almost like the line is frozen inside fzr dr, is this possible...
Yes, it is possible. Disconnect the water line under the freezer door, put the end of the tube in a bucket and push the water dispenser release lever. If water comes out with good pressure then the water line inside the freezer door is frozen.
Make sure the temperature in the freezer is not bellow 0°F. Unplug the refrigerator and defrost it with the freezer door open.
Here are the breakdown diagrams and Replacement parts for General Electric PSC23SGMDBS Refrigerator | AppliancePartsPros.com
Broken Kenmore Refrigeration Door Pivot (Refrigerator & Freezer Repair)
by Guest 3/16/2023 8:40:18 PM(UTC)
KitchenAide KSSS48QDX05 - all refrigeration repairs failed to restore cooling (Dishwasher Repair)
by bigpcman 6/8/2019 9:27:25 AM(UTC)
True Refrigeration (Refrigerator & Freezer Repair)
by ricky1842 6/21/2011 7:46:03 PM(UTC)
sealed refrigeration system (Refrigerator & Freezer Repair)
by JENNY CHAN 8/11/2010 10:32:24 AM(UTC)
Refrigeration shut off, only lights working (Refrigerator & Freezer Repair)
by chowland 1/17/2009 2:22:48 PM(UTC)
LG- French Door Bottom Freezer is cold but refrigeration warm (Refrigerator & Freezer Repair)
by ktmguy 12/19/2008 10:12:10 AM(UTC)
