When this machine first goes into the pump out (drain) mode with the transmission idle the machine is very noisy, like a grinding noise. When the transmission engages after the power interuption, the spin and pump noise combination is dramatically reduced. Is this a bum transmission while in the "neutral" mode?
Thanks,
George
It may be. Since your machine is less than one year old, call Whirlpool (800-hiroper) and setup a service call.
Matt
I'll be fixing the unit myself. Any insight is appreciated.
Thanks,
George
It sounds like your transmission is bad. Why would you not call Whirlpool? A transmission is very expensive.
I had a chance to listen to an identical machine and it sounds the same. Must be the design.
George
Its normal sounds.. units these days are made of thinner metal and vibrations are louder...
