GeorgeG
#1 Posted : Monday, March 10, 2008 7:53:04 PM(UTC)
GeorgeG
When this machine first goes into the pump out (drain) mode with the transmission idle the machine is very noisy, like a grinding noise. When the transmission engages after the power interuption, the spin and pump noise combination is dramatically reduced. Is this a bum transmission while in the "neutral" mode?
Thanks,
George
Matt S
#2 Posted : Tuesday, March 11, 2008 2:13:07 PM(UTC)
Matt S
It may be. Since your machine is less than one year old, call Whirlpool (800-hiroper) and setup a service call.
Matt
GeorgeG
#3 Posted : Wednesday, March 12, 2008 9:23:54 AM(UTC)
GeorgeG
I'll be fixing the unit myself. Any insight is appreciated.
Thanks,
George
Matt S
#4 Posted : Wednesday, March 12, 2008 2:01:43 PM(UTC)
Matt S
It sounds like your transmission is bad. Why would you not call Whirlpool? A transmission is very expensive.
GeorgeG
#5 Posted : Friday, March 21, 2008 7:01:01 PM(UTC)
GeorgeG
I had a chance to listen to an identical machine and it sounds the same. Must be the design.
George
bambiblaster
#6 Posted : Saturday, March 22, 2008 4:23:17 AM(UTC)
bambiblaster
Its normal sounds.. units these days are made of thinner metal and vibrations are louder...
Guest (6)
