I've been trying to find help to get my oven working again. I couldn't find a diagram anywhere or repair information on replacing broken parts. I know that there is an ignitor for the oven but clueless as to what it look like or where to find it or if this is the problem. Everything else works just fine on the stove except heat fromthe oven. HELP!:confused:
Hi Jewilson, Remove the oven floor and the flame spreader to access the igniter (#14 on the gas controls break down diagram). Unplug the igniter and check for 120V coming to the igniter while the oven control calls for heat. If there is 120V - replace the igniter. - The part number for the oven igniter is AP3455359 Gene.
I have the sme problem. my oven will not lite. I changed the wireing around using the top bureners wire into the oven igniter wire and put the oven wire into the top burner wiring both the top and the oven wireing get a spark. What do you think?
My colic oven will not light. I did a little changing around wiring to see if I was getting current to my ignite rs. I changed my top burners wiring with my oven and i get a spark oven nob sparks the top burners and the top burner nob Sparks the oven. What do you think?
Hi curt60,
The first thing you have to do is put all wires back in their original position.
Then I need the complete model number of the unit and description of the original problem.
Post it as a new thread, please.
I put the wireing back. The oven is a Cloric, Model RLN385 VW, serieal nomber 9402276778. I think it is a 1991. Oven will not light.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi curt60,
Gene.[/quot
Model num. RLN3855 SERIL. 9402276778 Year I think 1991
I forgot to put in the brand. Coloric
Did you see the oven igniter sparking when you turned the oven thermostat "on"?
Can you hear or smell gas coming out of the pilot at this time?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Did you see the oven igniter sparking when you turned the oven thermostat "on"?
Gene. no spark but I do smell the gas when I turn on the oven dial I have a Caloric gas range model number. RLN385VW, serial number. P1142394N WI. I get no spark from the oven igniter. I do sell a little gas when I turn the nob to ignite the stove. As I told you I changed the wiring around to see if I could get a spark using the top burner wiring and I get a spark that way. I also connected the wiring that usually goes to the oven to the top burner and that made the top igniters spark. I put the wireing back. Now What?
