2 Pages<12
#11 Posted : 17 years ago
Bypass the ignition switch (under the oven thermostat knob).
If the oven igniter will spark then the switch is bad.
If it would not then the spark module has to be replaced.
- The part number for the oven ignition switch is AP4288312
- The part number for the spark module is AP100046
Here are the break down diagrams for the Caloric range Model RLN385UW
curt60
#12 Posted : 17 years ago
curt60
Buy pass does that mean unhook the wiring under the oven thermostat nob and touch them together? did that no spark. I also noticed another thing. When I turn on the top left burner to light and it sparking and then I turn on the oven thermostat nob the oven will light. does this mean Spark modual needs replaced?
#13 Posted : 17 years ago
Yes, it does.
2 Pages<12
