Recently my fridge has apparently quit cooling but the freezer still freezes as it is supposed to. It appears to be running normal just not keeping anything cold. Anyone ran into this before? This is a Haier 18.2 refrigerator. This is probably basic but I am a novice in this area. Suggestions
My Roper refrig./freezer is not working. The freezer is fine but the fridge is warm. What do I do? It seems many people have this problem. I don't have the model # right now. Also, who repairs these appliance?
For both of you, go to my comments for Dinatl's GE fridge except ignore last web site.
FOUND IT!
I'm new to this. How do i find Dinatl's posting? I have a Kenmore trio with the same problem: fridge is warm, bottom freezer is fine.
Post your make and model#.
2005 Kenmore Trio Model 596.76523500. Thanks
Don't even know how this fridg works, hope someone knows
IM very basic terms it sounds like there is an air flow problem from the freezer to the refrigerator section. The easiest things to check for are on the back wall of the freezer look for snowy frost. That indicates either a defrost issue or a possible evaporator fan issue. Unfortunately this may be a job for a service company to repair. check your controls also so that the damper is open, letting air come into the refrig section from the freezer.
Check your damper control in the fridg. section, might be broken shut. If ok and works, replace the thermistor in the fridg. section P# 12002356. Damper control is P# 67003903
