fcharcoal
#1 Posted : Monday, November 23, 2009 10:52:16 AM(UTC)
fcharcoal
when i push the to start it wont come on just clicks
SublimeMasterJW
#2 Posted : Tuesday, November 24, 2009 9:00:22 AM(UTC)
SublimeMasterJW
r Pics
To get to the heating element on most of these dryers you remove the back dust cover:
UserPostedImage
1. Hi Limit (small limit upper right hand side of this pic)
the most frequent problem if dryer RUNS but no heat.
2. Heater assembly. 7. Control thermostat(s).
5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element
(if you do not have a meter remove and inspect this heater coil for breaks).
SublimeMasterJW
#3 Posted : Tuesday, November 24, 2009 9:04:09 AM(UTC)
SublimeMasterJW
Front panel removal.doc (136kb) downloaded 38 time(s). A betta look at dat fuse:D
SublimeMasterJW attached the following image(s):
Maytag Dyer Flame Does Not Stay Lit (Dryer Repair)
by jgwalter 1/28/2013 9:03:12 AM(UTC)
Maytag dyer igniter install for dummies (Dryer Repair)
by Jamnryan 1/27/2012 10:09:00 AM(UTC)
Maytag dyer motor problems (Dryer Repair)
by TRULUCK 11/24/2009 12:36:07 PM(UTC)
by TRULUCK 11/24/2009 9:40:02 AM(UTC)
