when i push the to start it wont come on just clicks
r Pics To get to the heating element on most of these dryers you remove the back dust cover: 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element (if you do not have a meter remove and inspect this heater coil for breaks).
Front panel removal.doc (136kb) downloaded 39 time(s). A betta look at dat fuse:D SublimeMasterJW attached the following image(s):
