jamn424
#1 Posted : 17 years ago
jamn424
I'm not a savvy with fixing dryers at all.
Problem:
Dryer does not work when start button is selected. All I hear beeps, but it does not spin at all. :(
Fact:
When pressing button on control panel, I hear sound and beeps at every button selection. It's a digital panel.
Any help would be really appreciated. I've replaced thermal limiter but that didnt do anything. Any help would be appreciated.
#2 Posted : 17 years ago
The first thing I would check if there is 240V at the power outlet.
If there is nothing wrong, remove the bottom panel and look for an envelope with the tech sheets. Perform the troubleshooting according to the instructions from the tech sheets.
jimbrown
#3 Posted : 17 years ago
jimbrown
I'm having the same problem. It's been a month or so since you posted the above, so I'm wondering if you've had any luck with repairing this problem.
I'm wondering if it's perhaps a problem with the thermal limiter, but that's just a guess based on some of the reading on the web and the manual.
Did you have any success with resolving your problem?
richappy
#4 Posted : 17 years ago
richappy
You both will need a meter to check things, otherwise we all are just making guesses.
jimbrown
#5 Posted : 17 years ago
jimbrown
I broke down and called a repairman. He said the problem is the temperature control mechanism. He used an ohmeter to test the current (after looking at the electrical diagram for the dryer to find the right wiring to test) which indicated that it was indeed the problem. If our problems are the same and you know your way around an electrical diagram, I would download the diagram from the Frigidaire site (for this specific dryer) and find the temp control wiring and use an ohmeter to test this.
Good luck.
electric dryer does not start (Microwave Repair)
by RayU 11 years ago
Dryer does not start (Dryer Repair)
by Kalalau 12 years ago
by hibidwns 13 years ago
by Bharat 13 years ago
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 13 years ago
by Raymond S 14 years ago
by cpboudreaux 14 years ago
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 14 years ago
Dryer does not start at all (Dryer Repair)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 15 years ago
by D_Druz 15 years ago
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 15 years ago
dryer does not start (Dryer Repair)
by petecardenas 15 years ago
by bellaboo 15 years ago
