We have noice that our washer is spinning so fast it sounds like an airplane engine taking off. at times when the spin cycle is done its still wet. :confused:
Most likely the cause of the problem is the drain pump bearing. Lift the washer form the front, remove the belt and check how free the pump pulley is moving. - The part number for the drain pump is AP3447809 Gene.
