starla87
#1 Posted : Sunday, February 24, 2008 2:38:58 PM(UTC)
starla87
We have noice that our washer is spinning so fast it sounds like an airplane engine taking off. at times when the spin cycle is done its still wet.
:confused:
#2 Posted : Monday, February 25, 2008 12:47:06 PM(UTC)
Most likely the cause of the problem is the drain pump bearing.
Lift the washer form the front, remove the belt and check how free the pump pulley is moving.
- The part number for the drain pump is AP3447809
