Randy Strickland
#1 Posted : Saturday, February 23, 2008 6:51:34 AM(UTC)
Randy Strickland
My Broan compactor is jammed (the ram is in down position). I removed the back panel and discovered the teeth on the small top gear are completely worn off. It seems that the ram may be stuck on something. Is there a way to manually raise the ram?
skeeter
#2 Posted : Sunday, April 6, 2008 1:36:41 PM(UTC)
skeeter
Randy,
Use a 15/16" socket(I believe that is the size) with ratchet on the sprocket nut to raise the ram.
Broan Compactor Jammed (Garbage Disposer Repair)
by deniseban 9/29/2008 2:43:14 AM(UTC)
