MalikR
#1 Posted : Monday, June 10, 2024 3:04:18 PM(UTC)
MalikR
The microwave light bulb on this 20+ years old Whirlpool Oven/Microwave wall-mounted combo ModelGMC305PDB2 has failed. I need to figure out how to pull out the microwave to replace the light bulb on top.
I had seen a video some 10 years ago but can't find it any longer.
EDIT: Found a fairly close video
here and accessed the light bulb. The circuit indicates it is the only item using the 12V output of a dedicated transformer.
Steps:
1- Remove two screws holding each of the side trims. Pry the trim out by sliding it down.
2- Remove the two side screws to disengage the interface panel.
3- Remove the microwave vent grill.
4- Remove the oven vent grill.
5- Remove two screws holding the microwave in place. Pull the microwave about 1/2 way out.
6- Remove the spring clip holding the lamp assembly.
7- Replace the halogen lamp without touching its surface with bare hands.
8- Follow the steps in reverse to put everything back together.
Edited by user Monday, June 10, 2024 6:14:12 PM(UTC)  | Reason: Solved update
applianceaid1
#2 Posted : Monday, June 10, 2024 8:03:35 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
Hi,
That should help others....thankx!
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
