mbay14
#1 Posted : Thursday, August 11, 2022 4:34:41 AM(UTC)
mbay14
Last week refrigerator froze milk solid (was not in freezer)
unplugged unit with frig and freezer set to recommended setting.
2 days later ice turned to water and food in frig warm ???
2019 Maytag refrigerator compressor fails to run
Mod # MRT118FFFH01
1. Capacitor was tested 200K ohm setting
reading started off and clocked to OL
when terminals were flipped readings did the same. (Pass)?
2. Start relay with two pins on top
single on bottom
< 1 ohm two top terminals
Full continuity from bottom single terminal to top terminal we are 120 V supply plugs in.
Refrig plugged in 120 V across to two wire plug (pass)?
3. Compressor readings across two bottom pins equals 10 ohms
right bottom to top 6 ohms
left bottom to top 6 ohms
Compressor test; 1 lead grounded then each individual pin touched = OL
Unit is only 3 Years Young
Any Known problems
Thanks.
Edited by user Friday, August 12, 2022 5:37:28 PM(UTC)  | Reason: Not specified
