Last week refrigerator froze milk solid (was not in freezer) unplugged unit with frig and freezer set to recommended setting. 2 days later ice turned to water and food in frig warm ??? 2019 Maytag refrigerator compressor fails to run Mod # MRT118FFFH01 1. Capacitor was tested 200K ohm setting reading started off and clocked to OL when terminals were flipped readings did the same. (Pass)? 2. Start relay with two pins on top single on bottom < 1 ohm two top terminals Full continuity from bottom single terminal to top terminal we are 120 V supply plugs in. Refrig plugged in 120 V across to two wire plug (pass)? 3. Compressor readings across two bottom pins equals 10 ohms right bottom to top 6 ohms left bottom to top 6 ohms Compressor test; 1 lead grounded then each individual pin touched = OL Unit is only 3 Years Young Any Known problems Thanks. Edited by user Friday, August 12, 2022 5:37:28 PM(UTC)
| Reason: Not specified
