Thank you very much for your help. I will order the part tonight and let you know what happens. Thanks again. Originally Posted by: Gene If the EOC has incoming power but nothing goes out then the EOC most likely is bad. - The EOC Part number: AP3874704
Gene: I changed the EOC. The F20 is gone and the range works perfectly. The cooktop doesnt work still. It has power going to the controllers but when you turn them on nothing happens. Any ideas? Thanks BB Originally Posted by: Gene If the EOC has incoming power but nothing goes out then the EOC most likely is bad. - The EOC Part number: AP3874704
Is there a reset botton or something? THanks, Originally Posted by: bboustany Gene:
Thanks BB
There are no reset buttons and/or fuses. Most likely the problem is a bad power supply board (#99 on the diagram). It provides power for all surface elements control boards. - The power supply board Part number: AP3874766
