Hello,
My KitchenAid electric oven is over 10 years old, and I had already replaced the control board. Now when starting the oven the control panel lights up, but when I set the function and temperature- No Heat! No bake, no broil, no roast, no convection heat. Have not recently run clean cycle.
Any suggestions where to start?
Thank you, /Peter F.
Thank you for this reply. Can I power the oven off/on then perform the board programming as described in the tech sheet?
/Peter F.
I cycled the power off/on then programmed the control board. Still no heat. What is next step: Thermal fuse or temp. sensor?
To be clear, I replaced the oven control board several months ago after erratic oven operation, and it has been working great until now.
TY!
/Peter F.
Originally Posted by: ohm ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Can give you your tech sheet. +1 ![UserPostedImage](https://gshort.click/buluhidung/75/a.png)
