belfair laundry
#1 Posted : Saturday, June 2, 2018 3:32:25 PM(UTC)
belfair laundry
i have to commercial gas dryers that are not getting hot i have changed out the thermostats, thermister, igniter, sail switch and i have checked the solenoids i'm on to removing the flame sensor but the screw is stuck and i cant get it out no matter what i do i'm not sure what it could be if its not that any help would be amazing. Its a large commercial Maytag dryer. or if you know hot to get a screw out of metal in a very tight spot.
gas hot water heater flame sensor (General Talk)
by normpete 1/21/2022 9:10:29 AM(UTC)
Gas dryer flame sensor not tripping (Dryer Repair)
by Guest 6/1/2021 7:32:22 PM(UTC)
Igniter, flame sensor, soleniods, thermal sensor all OK - but no heat (Dryer Repair)
by silentrunningpc 9/1/2016 4:34:36 PM(UTC)
No power to flame sensor, gas valves, or ignitor (Dryer Repair)
by ms0674 8/9/2014 2:37:45 PM(UTC)
Dryer Flame Sensor (Dryer Repair)
by TomHam 9/3/2013 1:00:20 PM(UTC)
Replaced gas coil, ignitor, flame sensor.. (Dryer Repair)
by dspcr 8/16/2013 4:12:54 PM(UTC)
flame stays lit for a few (20) seconds then goes out. could it be the flame sensor? h (Dryer Repair)
by grubxx96 11/11/2011 1:01:45 PM(UTC)
Kenmore replaced coils,ignitor,and flame sensor still no heat. (Dryer Repair)
by cfreeman 12/30/2010 10:31:48 AM(UTC)
Thermal fuse and Flame sensor wiring (Dryer Repair)
by cwizzards 5/7/2010 10:22:30 AM(UTC)
by Dangilligan 9/9/2009 5:34:55 PM(UTC)
relpaced coils and flame sensor and no heat (Dryer Repair)
by mjl 7/3/2009 2:20:19 PM(UTC)
Wiring Flame Sensor (Dryer Repair)
by TomGJohnson 6/9/2009 2:29:13 PM(UTC)
New flame sensor failure? (Dryer Repair)
by spiderberg 4/1/2009 6:54:40 AM(UTC)
Flame sensor (Dryer Repair)
by redrwut 2/21/2009 9:18:14 AM(UTC)
Which wire to which terminal on the flame sensor? (Dryer Repair)
by supertramp 1/13/2009 2:22:16 PM(UTC)
