dresstheman
#1 Posted : Saturday, December 30, 2017 5:17:12 PM(UTC)
dresstheman
My WP DW had the blinking clean (7x) light. Replaced the heating element and high limit switch - cleared the light using the - normal/heated dry reset sequence. Started to run a cycle seemed to run ok then heard it draining and light is still blinking 7x - any feedback appreciated.
#2 Posted : Saturday, December 30, 2017 8:05:15 PM(UTC)
Did you check the heating element for continuity prior to replacing it?
"...cleared the light using the - normal/heated dry reset sequence..." - can you describe it more detailed, please?
dresstheman
#3 Posted : Sunday, December 31, 2017 2:09:32 PM(UTC)
dresstheman
Yes - it was good but replaced it anyway due to age of DW - also replaced High Limit Switch - could it be Control Panel?
#4 Posted : Monday, January 1, 2018 9:13:21 PM(UTC)
I'm afraid I did not get it correct. Which part(s) did you replace due to the blinking clean light?
I also would like to hear from you exact sequence of buttons you used to reset control.
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
Whirlpool Quiet Partner II Not Drying (Dishwasher Repair)
by aronsmichael 6/2/2014 7:11:34 AM(UTC)
