My WP DW had the blinking clean (7x) light. Replaced the heating element and high limit switch - cleared the light using the - normal/heated dry reset sequence. Started to run a cycle seemed to run ok then heard it draining and light is still blinking 7x - any feedback appreciated.
Did you check the heating element for continuity prior to replacing it?
"...cleared the light using the - normal/heated dry reset sequence..." - can you describe it more detailed, please?
Yes - it was good but replaced it anyway due to age of DW - also replaced High Limit Switch - could it be Control Panel?
Originally Posted by: dresstheman Yes - it was good but replaced it anyway due to age of DW I'm afraid I did not get it correct. Which part(s) did you replace due to the blinking clean light? I also would like to hear from you exact sequence of buttons you used to reset control.
