I'm in Denver (high altitude has affected overtemp fuse burnouts in prev oven) and my 7 year old Kitchenaide Duel fuel slide-in, model KDSS907SSS04 oven is off temp.
Broil is sometimes ok but bake is usually 100˚F low. Checked temp sensor 1800Ω @ 72˚, overtemp thermostat OK, 30Ω lower bake element, 32Ω convection element, 40Ω upper inside broiler element, 47Ω upper outer broiler element. Both power legs are 120v.
Could it be something other than the Electronic Oven Control board?
Oven is off temp. Broil is sometimes ok but bake is usually 100˚F low. Checked temp sensor 1800Ω @ 72˚, overtemp thermostat OK, 30Ω lower bake element, 32Ω convection element, 40Ω upper inside broiler element, 47Ω upper outer broiler element. Both power legs are 120v.
