denverdave
#1 Posted : Friday, April 21, 2017 8:44:54 AM(UTC)
denverdave
I'm in Denver (high altitude has affected overtemp fuse burnouts in prev oven) and my 7 year old Kitchenaide Duel fuel slide-in, model KDSS907SSS04 oven is off temp.
Broil is sometimes ok but bake is usually 100˚F low. Checked temp sensor 1800Ω @ 72˚, overtemp thermostat OK, 30Ω lower bake element, 32Ω convection element, 40Ω upper inside broiler element, 47Ω upper outer broiler element. Both power legs are 120v.
Could it be something other than the Electronic Oven Control board?
denverdave
#2 Posted : Friday, April 21, 2017 8:47:07 AM(UTC)
denverdave
Oven is off temp. Broil is sometimes ok but bake is usually 100˚F low. Checked temp sensor 1800Ω @ 72˚, overtemp thermostat OK, 30Ω lower bake element, 32Ω convection element, 40Ω upper inside broiler element, 47Ω upper outer broiler element. Both power legs are 120v.
How to connect a Oven Control Board? (Oven Repair (including Ranges and Cooktops))
by orionlbb 2/28/2010 5:51:51 PM(UTC)
temp sensor or oven control board? (Oven Repair (including Ranges and Cooktops))
by Mike523 12/17/2007 7:13:11 PM(UTC)
