Door switch was bad replaced switch was replaced dryer still wont run when I bypass switch dryer works what is going on
Thought I had crossed the wires also so I switched them and still no go runs great when I tie the wires together and it does it hot it has one of those computer type boards could that be a problem?
How many wires go to the switch? If you have a light inside there should be three. One is common, one goes to the light (NC), and one goes to the motor(NO). Do you have a wiring diagram? https://www.youtube.com/watch?v=vs3npVPY76g![UserPostedImage](http://i.ebayimg.com/00/s/MTYwMFgxMjAw/z/-VgAAOSwnTJW~uhj/$_58.JPG)
Originally Posted by: Hoglover ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) No light works at a loss I know I'm really tired, but what does this even mean? Its not even a real sentence.You say your dryer starts if you short the wires together. That leaves three possibilities. (A) the switch is bad. (B) The wires are on the wrong terminals of the switch. (C) The switch is not being depressed for some reason. I'm done. No more.
