Washing machine wont agitate or spin. Coupler is not damaged. Help
Joined: 7/27/2010(UTC) Posts: 1,395  Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Will it fill with water and then drain the water out?
Does the motor run or do anything?
fills with water...drains water but no agitation or spin. 'Kenmore 90 series model
motor sounds like it is running
Pull the motor off and check behind it. See if the end parts of the coupling still firmly attached to their shafts.
If the coupling isn't damaged, by hand try turning the half attached to the gearcase. If you turn it one way it should spin and if you turn it the other way it should agitate.
sorry just got your notice. the shaft turns both ways
Does this happen? "If the coupling isn't damaged, by hand try turning the half attached to the gearcase. If you turn it one way it should spin and if you turn it the other way it should agitate." You should be able to make the washer spin or agitate by hand.
when i turn it both ways it agitates both way. no spin
Well I guess you can call me a dummy. Went back and look closely at the coupling. Notice one hole on the rubber part was cracked and broken. Decided to invest a few coins to see if that fixed the problem. Of course it did. Had I looked more closely the first time I wouldn't have wasted your time. Thanks anyhow for the help.
When you said it would drain. I figured your coupling was bad. A lot of the time they just wear off the flat spots inside and that's all it takes. The last design of coupling is the best.
