titaniclocket6
#1 Posted : Thursday, December 1, 2016 7:11:19 AM(UTC)
titaniclocket6
Hi,
I have GE microwave JVM1440WH01. Following is the history of the problem...
It started with fan running when you simply open the door – Microwave still used to work no other problem
After sometime the inline fuse blue-off – I replaced that couple of times
Found Bottom Door Switch was faulty – replaced it and it worked for couple of days
Now there is power but no heat and no turn table, no humming sound.
I have checked following parts and all seems correct
Diode, Capacitor, Magenatron, Fuse, Door Switches
MICROWAVE THERMOSTAT CUT-OUT – WB27X10195 – it has zero resistance and closed by default, however MICROWAVE HOOD THERMOSAT – WB27X10194 is open by default (is this correct?). I assumed it should be like THERMOSTAT CUT-OUT – WB27X10195 but I bought the new one and it is also by default open. Now I am not sure what part is faulty. I will appreciate your guidance.
The GE microwave parts details can be found https://www.geapplianceparts.com...40WH01/1/0/0/0/MICROWAVE
Sbond005
#2 Posted : Thursday, December 1, 2016 7:37:17 AM(UTC)
Sbond005
Very interested to see what answers pop up. Having the exact same issue on my GE Profile PVM1790SR1SS and everything I saw pointed to the lower door switch, ended up just replacing all 3 switches and still having the same issue.
