AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
GE Microwave JVM1440WH01 - no heat and no turn table
Hi, I have GE microwave JVM1440WH01. Following is the history of the problem... It started with fan running when you simply open the door – Microwave still used to work no other problem After sometime the inline fuse blue-off – I replaced that couple of times Found Bottom Door Switch was faulty – replaced it and it worked for couple of days Now there is power but no heat and no turn table, no humming sound. I have checked following parts and all seems correct Diode, Capacitor, Magenatron, Fuse, Door Switches MICROWAVE THERMOSTAT CUT-OUT – WB27X10195 – it has zero resistance and closed by default, however MICROWAVE HOOD THERMOSAT – WB27X10194 is open by default (is this correct?). I assumed it should be like THERMOSTAT CUT-OUT – WB27X10195 but I bought the new one and it is also by default open. Now I am not sure what part is faulty. I will appreciate your guidance. The GE microwave parts details can be found https://www.geapplianceparts.com...40WH01/1/0/0/0/MICROWAVE
Very interested to see what answers pop up. Having the exact same issue on my GE Profile PVM1790SR1SS and everything I saw pointed to the lower door switch, ended up just replacing all 3 switches and still having the same issue.
Microwave Repair
