tehackett
#1 Posted : Thursday, November 17, 2016 5:54:46 PM(UTC)
tehackett
I am trying to replace a chest freezer thermostat and the probe is stuck in the tube. How do I get it out correctly without ruining anything? It is a 1986 Kenmore model 198.8151525 if that helps any. I have pulled pretty hard on it and it just doesn't want to come loose and slide out. I also took a piece of wire and have pushed it up the tube along side the probe trying to see if it were plugged or frozen and it went in a long way with no issues.
rg.splich
#2 Posted : Monday, December 4, 2017 12:27:52 PM(UTC)
rg.splich
te,
I've encountered exactly the same problem. If that monster weren't so big and worked so well, I'd replace it.
I was not able to probe the tube as far as you did - I used some piano wire and it stopped at about 4 inches deep no matter how I worked it.
There has to be a way to remove that capillary, how else would they have repaired it back in the day? If I find out how it is removed, I certainly will post it here.
Good luck,
Rich
Droid69
#3 Posted : Saturday, February 13, 2021 11:29:54 AM(UTC)
Droid69
Anyone ever find out the answer to this? I'm having the same issue.
Guest
#4 Posted : Saturday, May 28, 2022 7:20:53 AM(UTC)
Guest
Groups:
am trying to replace a chest freezer thermostat and the probe is stuck in the tube. ... Stock up on groceries with this GE manual defrost chest freezer. G E 7 cu Ft chest freezer
Guest
#5 Posted : Tuesday, July 5, 2022 8:33:23 AM(UTC)
Guest
Groups:
Anyone figure it out. Same issue here!
Guest
#6 Posted : Saturday, September 3, 2022 4:18:08 PM(UTC)
Guest
Groups:
Is it possible the probe is attached to something ? I don’t get it
#7 Posted : Saturday, September 3, 2022 6:38:30 PM(UTC)
In order to provide most accurate advice we need the complete model number of the refrigerator. It's also better to register on the forum.
Guest
#8 Posted : Sunday, September 4, 2022 4:20:13 PM(UTC)
Guest
Groups:
Ok I got my stuck probe out, sprayed power lube up the tube a couple times , let it soak a long day, clamped visegrip on the end probe and tapped it with a small hammer. It started to move and then pulled it out . Hope this helps, hate to see a good freezer scrapped
#9 Posted : Sunday, September 4, 2022 5:57:52 PM(UTC)
Thank you for your reply. It was very helpful.
