Mbrondum
#1 Posted : Friday, September 16, 2016 12:05:09 PM(UTC)
Mbrondum
Approximately three months ago I started noticing that my oven would heat up to the desired temperature but would not maintain the temperature. I do not use the oven often so I did not think much of it at that Time, I figured I would fix it at a later date. Approximately two weeks ago I tried to start the oven so I could monitor the problem and as soon as I set the oven temperature The oven beeped as if the temperature was reached without even starting the oven. I first tried unplugging the oven to see if there was an error code that would come up and I got F3. I followed a post on this forum and went through the first steps of fixing it based on recommendations from Gene. Number one change oven sensor-check. Still got the F3 error. Number to change the oven sensor plug and replace with porcelain wire nuts – check. Still got F3 era code. Number three change control panel – check. Still getting F3 era code. Any suggestions?
Mbrondum
#2 Posted : Wednesday, September 28, 2016 3:39:01 PM(UTC)
Mbrondum
Anyone have a suggestion?????
GE JGB700SEJ4SS - F3 ERROR CODE (Oven Repair (including Ranges and Cooktops))
by tgdolemite 9/11/2022 6:10:01 AM(UTC)
E2 F3 error code (Oven Repair (including Ranges and Cooktops))
by garyabone@att.net 12/30/2015 2:52:36 PM(UTC)
F3 error code, even after replacing thermal sensor (Oven Repair (including Ranges and Cooktops))
by wskalyo 1/19/2013 1:33:17 PM(UTC)
F3 error code?? (Oven Repair (including Ranges and Cooktops))
by BOVENGE 12/20/2012 2:33:03 PM(UTC)
Blower won't turn off / F3 error code (Oven Repair (including Ranges and Cooktops))
by Peterpaolo 11/13/2012 4:16:37 PM(UTC)
F3 Error Code (Oven Repair (including Ranges and Cooktops))
by RangerOne 7/26/2012 3:47:51 AM(UTC)
Magic Chef F3 error code even after temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by ponderitsome 7/21/2011 3:46:26 PM(UTC)
front load washer f3 error code (Washer Repair)
by bo_okie1 7/15/2011 6:23:34 AM(UTC)
F1 and F3 error codes (Oven Repair (including Ranges and Cooktops))
by Rhandyman 3/23/2011 10:27:00 AM(UTC)
by Rhandyman 3/23/2011 10:25:34 AM(UTC)
Fisher & Paykel F3 error code :0 (Dishwasher Repair)
by Forkedupdishdrawerguy 11/29/2010 8:32:09 PM(UTC)
F3 error code on Frigidaire oven (Oven Repair (including Ranges and Cooktops))
by k75super 2/8/2010 7:38:15 AM(UTC)
F3 Error Code on GE SpaceMaker XL (Microwave Repair)
by Ckarolak 7/22/2009 12:29:23 PM(UTC)
by Eva 2/17/2008 10:22:04 AM(UTC)
Frigidaire Oven F3 error code (Oven Repair (including Ranges and Cooktops))
by sbochen 1/7/2008 1:58:12 PM(UTC)
