I checked on my washing machine a while after starting a wash because I didn't hear anything and the "Locked" light was on and it was doing nothing
After a few minutes, I held down the start button for a few seconds to unlock it and opened the lid to find the machine full of water. Nothing I have done since then has been able to get the machine to start spinning or draining again. I emptied it with a shopvac.
Your advice and suggestions are appreciated. I am guessing it is something simple.
Thanks! Karen
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Do you want to run a diagnostic to see what error codes pop up?
There is only one button-no diagnostic codes-a very basic machine.
There is a sequence of knob turns to put the machine in diagnostic mode which will display the error codes... I can explain if you are up to it.
I cannot do diagnostics on my machine. A repairman looked at the washer and there was a tiny piece of dirt that got lodged in the fins under the drain pipe!
Ok so are you back up and running?
