Started my dryer (Frigidaire feq1442es1), it beep three times, all indicator lights are on, but didn't start.
Changed almost every possible causes: door switch, thermal fuse, exhaust seal, and blower seal.
Check error code, nothing showed up.
Did the test run, drum run perfectly. But when I start, still beep three times and won't start.
Please help, thanks.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: brobriffin It used to show error code, but when I replaced the blower seal, the error code gone. However, it's still beeping and won't start. Thank anyway.
