TjaturSubagio
#1 Posted : Sunday, August 28, 2016 11:05:10 AM(UTC)
TjaturSubagio
Started my dryer (Frigidaire feq1442es1), it beep three times, all indicator lights are on, but didn't start.
Changed almost every possible causes: door switch, thermal fuse, exhaust seal, and blower seal.
Check error code, nothing showed up.
Did the test run, drum run perfectly. But when I start, still beep three times and won't start.
Please help, thanks.
brobriffin
#2 Posted : Tuesday, August 30, 2016 6:11:58 PM(UTC)
brobriffin
Man
As I'm sure you may have researched on the web there is a way to get the error codes. Here is the method to find out the error. http://manuals.frigidaire.com/p...f/Webster/134859700e.pdf
TjaturSubagio
#3 Posted : Wednesday, August 31, 2016 4:34:21 PM(UTC)
TjaturSubagio
It used to show error code, but when I replaced the blower seal, the error code gone. However, it's still beeping and won't start. Thank anyway.
