Good evening, Our Maytag refrigerator is not cooling at all. I cleaned out the condenser coils and replaced the defrost control board. I looked at it again this evening and the cooper tubing in the back was frozen over. I have attached a picture. It is the larger piece that froze. If you look closely, it still has a bit of ice on the bottom of it. I also checked the drain and water ran through it just fine. What am I missing. Thanks in advance, Jerry jer1989 attached the following image(s):
If it's not cooling it looks like a floating restriction or some sort of system failure. Unfortunately these repairs tend to be expensive (about 800 bucks) and require a professional for sure to completely diagnose
