hickmancw
#1 Posted : Friday, January 29, 2016 9:39:31 AM(UTC)
hickmancw
no matter where my start knob is in the cycle the washer will only agitate. I have already changed the timer and it still agitates and does not fill. After a short time of agitating the washer will start spraying water like it is going into a rinse cycle. Any suggestions????
Joe / APP Team
#2 Posted : Friday, January 29, 2016 11:53:04 AM(UTC)
Joe / APP Team
Hickman, a couple of "easy" checks to make, make sure the drain pipe is at least 38 inches high from the floor level. Then check the lid switch Part number: AP3180933
. If the drain pipe is too low, the washer will "syphon" the water out and the washer will fill and wash until the water level is reduced and will repeat the process continuously. Since the motor runs and agitates, the motor and timer are not likely to be at fault. But if the lid switch isn't closed and making contact, the circuit for the drain/spin cycles won't be completed and the washer wont perform when the drain cycle is reached.
Whirlpool washer only agitates in one direction....(gsw9800pw2) (Washer Repair)
by Wee 1/25/2020 10:55:23 AM(UTC)
washer only agitates in delicate cycle (Washer Repair)
by wall 2/5/2015 2:41:27 PM(UTC)
Washer only agitates in one of three cycles (Washer Repair)
by daryltwo 1/10/2015 12:55:38 PM(UTC)
Whirlpool Washer Only Agitates In One Direction (Washer Repair)
by tenntod 1/20/2014 10:26:35 PM(UTC)
Estate washer only agitates in clockwise direction (Washer Repair)
by pbrooks259 8/24/2013 2:00:21 PM(UTC)
Washer only agitates and spins intermittently (Washer Repair)
by lukas_s 1/27/2013 11:20:35 AM(UTC)
maytag washer only agitates on permanent press (Washer Repair)
by Lizabell 12/10/2011 9:41:51 AM(UTC)
Washer only agitates, will not spin (Washer Repair)
by Miss Vickie 5/26/2011 11:15:53 AM(UTC)
Matag washer only agitates on delicate (Washer Repair)
by elfretz 10/27/2009 5:52:45 PM(UTC)
