Windersurf
#1 Posted : Saturday, January 2, 2016 1:35:36 PM(UTC)
Windersurf
I have a Kenmore 80 Series Top Loading Washing Machine that is having an issue that I have not been able to diagnose. The Washing Machine Model Number is 110 26882503. The Serial Number is CT 1340564 Type 111.
The washer tub fills with water fine but then does not transition to the agitation cycle. After the tank is full to the selected load level, the motor just humms and after a while throws the circuit breaker for the wall outlet.
When I change the dial setting to rinse / spin, the tub drains and the spin cycle works just fine.
The Agitator dogs seem to be fine because they catch properly.
I have replaced the Lid Switch and the Motor Coupler but the problem remains -- the agitator cycle does not function and the motor humms.
Can you tell me what the problem might be or what I should do to diagnose the problem.
From -- No clean clothes in Florida.
sidfink43
#2 Posted : Tuesday, January 5, 2016 4:14:54 AM(UTC)
sidfink43
I don't think it is the motor since it works fine through a complete rinse cycle of fill, agitate and spin. The potential problems could be the motor switch or the timer. Try replacing them one at a time and see if that doesn't fix your problem. If you buy the parts from this site you can return the one you don't need.
Windersurf
#3 Posted : Friday, January 8, 2016 6:26:41 PM(UTC)
Windersurf
Thanks for your response. The dial does not seem to advance automatically once the tub is filled. The motor simply humms until the wall power circuit breaker trips. Does that indicate that the timer is more likely to be the problem?
sidfink43
#4 Posted : Saturday, January 9, 2016 4:16:58 AM(UTC)
sidfink43
Probably so, since the motor switch rarely fails. But you will have to change it out to be certain.
Good luck.
Windersurf
#5 Posted : Sunday, January 10, 2016 9:32:39 AM(UTC)
Windersurf
Thanks much! I will try that.
