Earwicker
#1 Posted : Thursday, October 22, 2015 8:41:41 AM(UTC)
Earwicker
for Whirlpool WOS 51 EC 27 inch wall oven, can bake element be replaced entirely by removing back panel, or must a side panel be removed also? Whirlpool cust svc, parts, repair could not answer this question.
bizkid23
#2 Posted : Friday, October 23, 2015 6:20:17 AM(UTC)
bizkid23
On phone internet and can't look at diagram but...
When you unscrew the element from inside the oven see if you can pull it out a couple of inches. Usually there is enough slack in the wire that you can change without back panel access at all. Just be careful that it's unplugged and not to pull the wire off the element by tugging too hard.
Earwicker
#3 Posted : Saturday, October 24, 2015 12:26:45 PM(UTC)
Earwicker
Thanx for your help. This Whirlpool has "hidden bake" which is an oven floor that completely blocks heat element when approached from front. I learn internet that GE oven with "hidden bake" must have BOTH rear panel and left panel removed to reach bake element from back. Oven sticks into my garage and left panel is not acessable unless oven is removed from wall. You tube shows a LG and a Samsung where job can be done entirely from back panel. Old Kenmores, maybe whirlpools had two screws in rear of "hidden bake" floor but this model seems like floor is integral with sides.
erichiltonanderson
#4 Posted : Saturday, January 29, 2022 2:42:47 PM(UTC)
erichiltonanderson
You take off the back service panel, and the left and right panels and insulation. Remove the tray bleow the bake element. THen you can get at the bake element.
Replace bake element on electric range/oven (Oven Repair (including Ranges and Cooktops))
by bad Dog 2/24/2019 9:17:21 AM(UTC)
Replace Bake Element (Oven Repair (including Ranges and Cooktops))
by savehailey 6/18/2010 1:22:08 PM(UTC)
Replace Bake Element, Remove Oven Bottom (Oven Repair (including Ranges and Cooktops))
by jcarbeck 1/6/2010 6:44:45 AM(UTC)
how to replace bake element (Oven Repair (including Ranges and Cooktops))
by moult2850 12/2/2009 12:20:48 PM(UTC)
replace bake element; doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jpatch3 7/6/2009 6:06:48 PM(UTC)
Replace Bake Element-Whirlpool self-cleaning oven (Oven Repair (including Ranges and Cooktops))
by rpettet 6/21/2009 12:12:25 PM(UTC)
How do I replace bake element (Oven Repair (including Ranges and Cooktops))
by csonka 5/7/2009 1:58:41 PM(UTC)
Just replace bake element takes more than 30 minutes to heat (Oven Repair (including Ranges and Cooktops))
by AandRelectric 5/5/2009 10:12:26 AM(UTC)
Remove & replace bake element (Oven Repair (including Ranges and Cooktops))
by Suzipat 4/30/2009 6:52:02 AM(UTC)
MAytag performa replace bake element (Oven Repair (including Ranges and Cooktops))
by bacrath 5/5/2008 6:03:35 PM(UTC)
How to replace Bake element? (Oven Repair (including Ranges and Cooktops))
by patchas 12/27/2007 5:10:33 PM(UTC)
