AandRelectric
#1 Posted : Tuesday, May 5, 2009 10:12:26 AM(UTC)
AandRelectric
Bake element burned itself with blue flame while preheating. Just replaced it and the front display panel that had been out for years.
Front panel works great but waited over 30 minutes for bake element to preheat to 375 and then had to use broil to get it there.
Husband checked back panel with meter and said only 120 volts -- no power on board side.
Any suggestions?
#2 Posted : Tuesday, May 5, 2009 1:35:39 PM(UTC)
Most likely the problem is a bad Bake relay on the relay board (#29 on the diagram)
- The part number for the relay board is AP4008573
Here are the breakdown diagrams and Replacement parts for JENN-AIR SVE47600B | AppliancePartsPros.com
