Scottginct
#1 Posted : Saturday, April 18, 2015 6:37:09 AM(UTC)
Scottginct
Spin cycle does not engage.
Replaced clutch assembly and motor coupling.
Wash cycle works but when going into spin it sounds like it is seizing and stops.
I shut it down and unplug, turn off water then it leaks.
I have checked pump and hoses.
Could this be a pump or gearbox issue?
fairbank56
#2 Posted : Saturday, April 18, 2015 10:49:58 AM(UTC)
fairbank56
If it won't drain, then it may be something in the pump jamming the motor. With tub empty, set timer directly to spin. If it won't spin, you need to run the machine with cabinet removed and lid switch bypassed so you can observe the clutch hub. When in spin cycle, if the clutch hub is not spinning, pull the pump off the motor and try again. If clutch hub still won't spin, then the transmission is faulty.
Eric
UserPostedImage
WHIRLPOOL spin cycle (Washer Repair)
by acce 10/3/2016 5:20:48 AM(UTC)
Whirlpool spin cycle only metallic banging (Washer Repair)
by Mapman1701 10/17/2013 8:22:23 AM(UTC)
Pause in whirlpool spin cycle (Washer Repair)
by golfman 2/12/2011 1:31:58 PM(UTC)
Whirlpool spin cycle noise (Washer Repair)
by Tim1000 8/20/2009 7:41:45 AM(UTC)
