AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't spin out all the water from clothes
The washer will spin but does not completely spin all the water out of the clothes. Sometimes the spin cycle needs to be run multiple times and the cloths still need to be rung out by hand.
I'm thinking it's the clutch assembly but I'm open to other suggestions.
Need the correct model number of the washer.
Eric
LSN1000LW3 ... I took the clutch ring off and some of the pads are worn. I was able to spin it fairly easy. Also a little greasy buildup I cleaned up.
Sounds like that's your problem then?
Eric
Washer Repair
