hall9107
#1 Posted : Thursday, January 29, 2015 10:04:39 AM(UTC)
hall9107
My dryer constantly overheats and blow thermal Fuses. I have thoroughly cleaned my ventilation ducting and replaced the thermal fuses three times. I have also replaced the thermistor, the thermostat and the cutout. I had a repair technician come over. He said that the dryer fault system indicated insufficient inlet airflow, and everything else checked good. I rechecked my vent ducting and it is perfectly clear; but the dryer continues to overheat. What else could be causing this overheating problem? Please help!
#2 Posted : Friday, January 30, 2015 1:30:52 AM(UTC)
Parts for Maytag MEDE300VF0 Dryer - AppliancePartsPros.com
I think it is the correct one but am guessing a bit on this.
Did the tech check for a grounded element?
Were the exhaust temperatures checked?
Was the exterior vent checked when the duct system was checked?
File Attachment(s):
MEDE300.pdf (1,242kb) downloaded 3 time(s).
