jgmann
#1 Posted : Tuesday, October 28, 2014 11:58:22 AM(UTC)
jgmann
The left hinge on my oven door doesn't move correctly to close the oven door. It doesn't snap back to the full upright position and pull the door closed. I see that this problem occurs on Jenn-Aire wall ovens and I was wondering if the combination of a new gasket, hinges and the door liner as I see recommended for similar problems would do the trick? Thank you.
#2 Posted : Tuesday, October 28, 2014 2:03:33 PM(UTC)
Parts for Jenn-Air JES8850BAS Range - AppliancePartsPros.com
If the other parts look OK why not just repalce the hinge (item 4 in Section01)?
As long as you are sure it is just the left hinge.
jgmann
#3 Posted : Wednesday, October 29, 2014 5:15:54 AM(UTC)
jgmann
Originally Posted by: denman Go to Quoted Post
Thank you denman, I'll give that a try first.
