The left hinge on my oven door doesn't move correctly to close the oven door. It doesn't snap back to the full upright position and pull the door closed. I see that this problem occurs on Jenn-Aire wall ovens and I was wondering if the combination of a new gasket, hinges and the door liner as I see recommended for similar problems would do the trick? Thank you.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you denman, I'll give that a try first.
