I just moved into a new to me house. The stove has an element with a problem. If we put it higher than low, it goes to high and stays there until we turn it off - even if we change the setting, it is ignored (unless it is turned off).
Is this a problem with the element, or the receptacle, or something else?
THIS FORUM IS DEAD!!!!!!! |
