wbmoore
#1 Posted : Thursday, September 11, 2014 6:19:03 AM(UTC)
wbmoore
I just moved into a new to me house. The stove has an element with a problem. If we put it higher than low, it goes to high and stays there until we turn it off - even if we change the setting, it is ignored (unless it is turned off).
Is this a problem with the element, or the receptacle, or something else?
#2 Posted : Friday, September 12, 2014 12:49:12 AM(UTC)
Parts for Frigidaire FED300ESC Range - AppliancePartsPros.com
The problem most likely is the infinite switch (item 54 in section 03)
