At 1st I thought it might be 1 of the bearings on the motor or the belt pulleys. After removing the access cover & inspecting, it is obvious that's not it. While down there, it is clear the noise is coming through the vent. I think I can fix it if you think you know what it might be & have the parts. Any help would be greatly appreciated.... Thanks in advance, Chris
THIS FORUM IS DEAD!!!!!!! |
Thanks for the quick reply. I went ahead & ran it later that evening after cleaning up inside that access cover & duct. It spit out a couple dozen pebbles/pea gravel, some more dust & dirt, and about 15 minutes later the noise stopped. Maybe all that stuff got shook loose while I was sliding the machine out of it's spot? I don't know, but I'll certainly hang onto your information. Thanks again, Chris
