steveherman
#1 Posted : Sunday, June 8, 2014 4:28:21 AM(UTC)
steveherman
So far I have put in a new Cam Agitator Repair Kit, a Direct Drive Washer Motor Coupling, and a new Clutch Assembly.
The noise is kinda like a slam then a millisecond grind at the end and then repeats as the agitator moves.
I will DOUBLE CHECK this afternoon but I think the agitator is ONLY MOVING IN ONE DIRECTION.
Hopefully this description can give you guys enough to help me figure it out.
Steve
fairbank56
#2 Posted : Sunday, June 8, 2014 6:37:44 AM(UTC)
fairbank56
The top part of the agitator (auger) only goes in the clockwise direction. If the lower agitator is only going in one direction, then the transmission is bad.
Eric
steveherman
#3 Posted : Sunday, June 8, 2014 11:53:40 AM(UTC)
steveherman
ok i am home.
the top part of agitator does go clockwise.
the bottom goes back and forth... until you start adding laundry... then everything starts going counterclockwise.
does that help?
Thank you.
Steve
fairbank56
#4 Posted : Sunday, June 8, 2014 2:25:29 PM(UTC)
fairbank56
GE top loader washer making noise during agitation coasting (Washer Repair)
by smoss 8/16/2021 5:36:56 AM(UTC)
GE washer noise during agitation (Washer Repair)
by nikkibee 5/9/2016 10:54:51 AM(UTC)
by speckles1 1/27/2016 1:29:41 PM(UTC)
GE Noise During Agitation (Washer Repair)
by AiwaSoundSystem 10/12/2015 10:39:28 AM(UTC)
GE washer: Clicking noise during agitation (Washer Repair)
by mtncycling 1/23/2015 1:49:23 AM(UTC)
thumping noise during agitation (Washer Repair)
Belarus uniqueone 7/24/2014 3:48:57 PM(UTC)
Loud grinding noise during agitation (Washer Repair)
by pete172 10/5/2013 6:32:47 PM(UTC)
Kenmore washer making banging noise during agitation (Washer Repair)
by daverdfw 9/3/2013 9:48:38 AM(UTC)
Strange clunking noise during agitation cycle (Washer Repair)
by myslyn 6/27/2013 5:31:04 PM(UTC)
centrifugal switch/motor noise during agitation (Washer Repair)
by jrsweger 4/14/2013 10:42:14 AM(UTC)
loud noise during agitation only, belt and pulleys move fine both ways (Washer Repair)
by paljohkim 4/5/2013 1:59:17 PM(UTC)
GE top load washer make grinding noise during agitation and spin, but work fine, just (Washer Repair)
by dchanson55 1/21/2013 4:11:28 PM(UTC)
Washer noise during agitation (Washer Repair)
by McLyle 8/28/2012 1:44:55 PM(UTC)
High, schrill metal bearing noise during agitation (Washer Repair)
by jimgilles 5/19/2012 8:33:12 AM(UTC)
fix me! Maytag clicking noise during agitation/spin (Washer Repair)
by jjeff 10/6/2011 9:49:41 AM(UTC)
