lobo7448
#1 Posted : Monday, March 10, 2014 10:44:55 AM(UTC)
lobo7448
Replaced heating element and thermostat, but dryer is still not heating.:eek:
#2 Posted : Tuesday, March 11, 2014 2:10:47 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Jenn-Air JDE2000W Dryer - AppliancePartsPros.com
The first thing to do is check the power. The heating coil requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
