Replaced heating element and thermostat, but dryer is still not heating.:eek:
Here are your parts includes a wiring diagram. Parts for Jenn-Air JDE2000W Dryer - AppliancePartsPros.comThe first thing to do is check the power. The heating coil requires the full 240 volts. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
