I have a GE over range Advantium Model # SCA1000HCC 03 Serial # FL900001 K Mfg March 2006 and purchased last summer The plastic door latch piece snapped off -- I reattached it with super glue This is only temporary == I know what part is needed -- door latch spring assembly Part # WB10X10021 How do I remove the old one and install the new part -- in particular where are the screws hidden Westy
Originally Posted by: westhighlander I have a GE over range Advantium Model # SCA1000HCC 03
Serial # FL900001 K Manufacturer March 2006 and purchased last summer
Westy I'm having the exact same problem. I can find the part but can't figure out how to open the door assembly to replace it. Any help would be most appreciated. Thanks in advance.
1WB10X10021LATCH PAWL 1$10.00WB10X10021LATCH PAWL Its called a Latch Pawl part number wb10x10021.. The latch has broken a few times and the super glue has held but its not holding any.... more shame they didnt use better materials for the high use part...
Any council on how to access the latch is appreciated.
Taking off the inner door trim accesses the latch. There are no screws in the door trim or the latch. The latch lifts off two pins once the spring is loose. There are pictures on this page that will show how to remove the trim. GE Spacesaver Microwave Handle Replacement Note that this page is for replacing handles but there is a pictrue that shows how to remvoe the trim. Also sometimes the latch will not break but the hole that the spring connects will break. In that case i will drill a small hole in the metal door frame for the spring. Hope this helps!
