polecat97
#1 Posted : 17 years ago
polecat97
The ignitor does not go on. I put 110v to it and it glows. There is no juice to the ignitor.
bentwrench1999
#2 Posted : 17 years ago
bentwrench1999
ALWAYS DISCONNECT THE POWER BEFORE SERVICING! Have you located and checked your thermal fuse? It is located on the rear dryer bulkhead. It is a white ceramic piece with 2 smaller wires attached. About 2" long and 3/8" wide. May be stamped with a number 3392519.
You can TEMORARILY connect the 2 wires together to test. If dryer runs now you have found the problem. You will need to clean all airflow assemblys on the dryer and clean the exhaust duct.good luck..wrench:)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 10 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 12 months ago
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag about a year ago
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam about a year ago
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 about a year ago
No heat when assembled (Dryer Repair)
by Guest 2 years ago
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2 years ago
No heat, (Dryer Repair)
by tseibring 2 years ago
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 2 years ago
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 3 years ago
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 3 years ago
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 3 years ago
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 3 years ago
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
