all four burners work but do not get red hot
Here are your parts, includes a wiring diagram Parts for Frigidaire FEC30C4ACD Cooktop - AppliancePartsPros.comCheck the power to/at the unit. L1 to L2 voltage should be 240 volts. If OK then you will have to do a live test to see if the 240 is still good when an element is on. [COLOR="Red"]Be very careful as 240 volts is lethal.[/COLOR] If you do not have electrical experience then I would get in a pro. |
THIS FORUM IS DEAD!!!!!!! |
